Members jawilliams Posted October 13, 2008 Members Report Posted October 13, 2008 I started building sheaths and I want a smooth edge on a fold over sheath. I was told to sand the edge and then load a buffing wheel with bees wax and then run the edge over the buffing wheel and keep loading the buffing wheel and then the edge until I got what I wanted. Is this a good way to do this or is there a better way or ways? Thanks, James Quote
Members Kevin Posted October 13, 2008 Members Report Posted October 13, 2008 I haven't ever done that, but I would say try it on scrap first, 'cause it sounds like a good way to get a fuzzy edge and then you'll play hell trying to get the fuzz out of the bee's wax. If you are trying to even out uneven edges, I would sand, rough then fine, bevel the edge, wet it and rub until it is smooth enough. Then dye and burnish. Maybe that helps, Kevin Quote
Members Rawhide Posted October 13, 2008 Members Report Posted October 13, 2008 I agree with the sanding part, but the beeswax on the buffing wheel should be postponed until the edge is slick already. I would wet the sanded edge and then slick with a piece of hardwood or bone folder. then use the beeswax and you should get a good edge. Marlon Quote Marlon
Members jawilliams Posted October 13, 2008 Author Members Report Posted October 13, 2008 Thanks, it has been driving me nuts trying to figure this out. Quote
