Cowgirlup8807
Barely Used Techsew 3650 Hd
I have barely used this machine, I bought it brand new from Raphael Sewing in January 2014. It has been oiled regularly and has been used very lightly. I can take pictures of anything you'd like to see and will take apart and ship. I am asking $1,250 and can negotiate shipping costs. Sorry no trades.
It includes size 27 and 24 needles, as well as a left zipper foot along with everything below:
The Techsew 3650HD is a heavy material sewing machine designed for use in sewing projects such as horse tack repair, harnesses, holsters, bridles, horse blankets, heavy webbing, canvas, synthetics and more.
With its 7/16" sewing capacity and 10.5" long cylinder arm, the Techsew 3650HD makes large and heavy sewing projects a breeze. The Techsew SmartServo motor and speed reducer give you the highest amount of torque possible, while providing great speed control for slow stitching. This system is ideal for beginners, amateurs and professional sewers.
Features:
High presser foot clearance (1/2")
Powerful feed mechanism - for sewing thick and bulky items
Reverse stitch
10.5" long cylinder bed
Sews up to 7/16" thickness
Built-in Roller Guide - helps you keep your stitches straight and even
Sews 2 layers of 10-11oz leather, 3 layers of 9oz leather, and 4 layers of 7-8oz leather
Stitch length adjustment (7mm max length)
Equipped with Techsew SmartServo motor and speed reducer to sew at slow & controlled speeds - great for novice, amateur and professional sewers
New reinforced U-Table provides open space around the cylinder bed
Locking wheels makes the unit easy to move around, and locks in place during use
Includes complete table with locking wheels, motor, speed reducer, needles, bobbins, oiler, instruction manual, tools, bobbin winder, lamp.
Includes Limited Lifetime Warranty and FREE technical support for the life of your machine
Specifications:
Needle sizes: #23 to #27
Thread sizes: #69 to #350
Presser Foot clearance: 1/2"
Maximum stitch length: 7mm
Cylinder bed length: 10.5"
Table dimensions: 47 x 21 x 24 to 31.5" (adjustable height)
Techsew SmartServo motor: 600W, 4/5HP, 110V, 0 to 1800RPM, 18 speed settings with bright LED display.
Shipping to Houston TX, and please post photographs of the machine in detail . . . . thanks. IS it possible to sew lighter materials for packs, bags, etc. with needle/thread changes, as well as holsters, etc. as the machine was designed to do?
I see no reason that it shouldn't be able to do lighter materials as the description says. I have only sewn tack and heavy leather on it but it has several places to adjust tension on upper and lower threads and presser foot, needles are easy to change out and the feeder dogs have the ability to be moved up or down depending on what you want to do. The thread stand has places for more than one type of thread and the machine is easy to thread and has a bobbin winder. If you have specific questions I would call Raphael Sewing and see if it they know if you can sew that on it.
The photos that I have are too large to allow them to be posted on here, I have created a page on my website where you can see them. If I resize them they are too small and grainy to see the detail of the machine. http://www.legacyleatherco.com/techsew3650hd.html
I will work on getting a shipping quote, I may need your actual zip code though.
Shipping to Houston Texas can be as much as $250 depending on whether it's shipped freight or not.
I have a Techsew 3650 HD and have used it to sew lighter material, as well as holsters, belts, etc. It was my first machine. ( have a second for light material such as double layer 1-1/2 to 2-3 oz). The smallest needle I use is the 23 with 69 thread. I usually use a 160 thread, sometimes double stitching. The machine is easy to follow for double stitching. I have tried a 19 needle, but got skipped stiches, and was not wanting to take the trouble to readjust/retime for it, as I mostly use it for 2x or 3x 8-10 oz. I am very happy with it and have had/used it for 3 years. Got sidetracked- I have used it for wallets, if I am looking for the "heavier stitched look" and then 2x stitch with the 160 thread. If you use it for lighter material and will only single-stitch,, be aware that you will have the 23-sized stitch holes.
This machine is still available, PRICE HAS BEEN REDUCED!! I am asking $1,400 including freight shipping in the US! Freight shipping is ~$350-$400 for reference!
Edited by Cowgirlup8807
Reduced? Did I miss something? I thought it was originally $1250.
It was 1250 plus shipping which was indicated that it would be 350-400 which would make it a total of at least 1600. So it has actually been reduced.
That's correct earlthegoat2. :) I have actually just sold this machine, good luck to a new leather worker Jake! I can't wait to see what you are able to do with it!
