I curently use an awl to punch my stitching holes. I am wondering about the diamond stitching hole punches. Are the shape of the diamond hole better? If so why? Does it make it easier? Any and information would be appreciated. John
Does it make the stitching easier?
for my normal stitches I use the large overstitch wheel to lay out my stitch marks. So would that be the 4mm?? I want to get the ones that are the same distance as what I am useing now.
stitch with the overstitch, take a ruler and measure out how many stitches can fit within an inch. That is the Stitches per inch of your overstitch.
Stitches per inch on pricking iron and overstitch are the same scale.
the ones I looked at said 2mm 3mm 4mm etc.Even Tandy's say's Pro Line Diamond Stitching Chisel 2 Prong (5/64" (2mm) Spacing)
Thank you all for the help and information it is much appreciated. John
