About three months ago I bought a new Juki DNU-1541s. I've always wanted to make motorcycle seats, and I figured it was time to get started. I bought the machine unassembled from Winchester Sewing Machines. When it arrived, I thought I might be in over my head, but three days later, I had it assembled and working. I am basically teaching myself to sew.
Yesterday I decided to change bobbins, and when I pressed the bobbin holder into place it didn't quite lock. I made several passes on my project, and suddenly I heard a thud and then a different sound coming from the machine. I discovered that he bobbin had popped out of place, and on further examination I found that the circular hook was not spinning. Nooooooo!! I thought I had broken my expensive, new sewing machine. :ranting2:
I made a couple of phone calls and found a local guy who works on industrial sewing machines. He came to my house after work and sat down to diagnose the problem, which he quickly found. There is a silver button on the base of the machine head. He showed me how to depress the button which locks into a cog under the base. While holding down the button, just spin the hand wheel backwards to re-engage the drive to the hook. He said that is a safety feature in the 1541. The hook disengages when the needle hangs or gets stuck. Whew. I didn't break it after all. :)
He showed me a few tricks like how to hold on to the end of the thread that goes through through the needle while I make the first stitch to keep the thread from fouling and disengaging the hook. It cost me $25 to get a lesson on how not to be a dummy, but it was well worth it. I'm back in business. :yeah:
  • 5 months later...
Thanks for posting this solution Earthling33, I just ran into the same problem and panicked as thought I broke the brand new machine I just got!! Solved it from your post!
Hanna
I had this problem too. Tried to call a sewing machine specialist, he wanted $150 just to look at the machine. I thought to look for an answer online, as I have already opened everything inside of the machine, that I could :) Finally I found a tutorial on Google and downloaded two manuals for my machine, one was for a service parts. Re-engaged safety mechanism - it was easy.
After all of that I found that all of this information inside of the sewing machine manual, which I have never read in a beginning :)))
Edited by olenawills
Hanna
Hanna
Hi Hanna,
I am very happy that my meager knowledge could help you out. Good luck with your Juki. I hope you post some of your work.
John
Read the manual??!! No way.
Seriously, I'm glad you got it worked out.
John
Exactly! :) But I took half of the machine apart and know how this mechanism looks inside out. Cleaned and old machine same time. :dance:
This is the help , that I found online, with the pictures and steps described
Re-engage the Safety Clutch on Walking Foot Sewing Machine
by KaceyK
My machine is Juki Ls-341 Cylinder Bed, but it worked for me too.
