Members austinb Posted June 5, 2014 Members Report Posted June 5, 2014 I had purchased a Keen edge beveler from Tandy to bevel the edges of my belts. I had purchased another beveler (can't remember the size) for edges, but it leaves them rather triangular, and I want something rounded. Any specific size or beveler I should get to achieve this? All of my belts are 1.5" Hermann Oak strips purchased from Springfield leather. Thanks! Quote
Members CTaylorJr Posted June 5, 2014 Members Report Posted June 5, 2014 You can get a rounded edge using a rounded type edge burnishing tool. Quote Charlie
Members TomG Posted June 5, 2014 Members Report Posted June 5, 2014 I do straps up to 1-1/2" and generally use a size 3 in that same model. For smaller and thinner leather I have a size 2 that I sue, but I found with the thinner stuff, if I lay it on top of a piece of scrap strap and flush up the edges, it cuts much easier and smoother. Quote Tom Gregory Legacy Leathercraft www.legacyleathercraft.com www.etsy.com/shop/legacyleathercraft
Members Nuttish Posted June 6, 2014 Members Report Posted June 6, 2014 Using a burnishing tool will only temporarily round the grain over the edge. I assume your Hermann Oak strips in that width are 12 oz+ bridle or similar temper and weight. You need to make some choices about removing material. If you wish to round the grain edge without substantially rounding the side edge, you can use a #2 (slight), #3 (slightly larger), #4 (biggest) standard edger e.g. https://www.osborneleathertools.com/product_details.php?pid=194. They have a round bottom, but are a monstrous pain in the ass to sharpen and never come from the factory with a useable blade. If you wish to put a larger radius on the edge, you might consider using a Bissonette edger. Held at a consistent angle on the top edge, they remove a consistent amount of material from the grain to the side edge and can also help evening little cutting issues. I can post some some example pics of each strategy if you wish. Quote
Members TomG Posted June 6, 2014 Members Report Posted June 6, 2014 I mounted a piece of 2mm (think that was the size) round lace to my stropping board with glue. Applied rouge and drag my #126 edgers down it every so often. I've never sharpened them, but that stropping makes a world of difference in how they cut. Tandy has an excellent book on use, care and sharpening on most tools. Quote Tom Gregory Legacy Leathercraft www.legacyleathercraft.com www.etsy.com/shop/legacyleathercraft
