Members Sluggo001 Posted June 5, 2014 Members Report Posted June 5, 2014 I make a lot of boxes with mitered and sewn corners. I normally make wooden forms to wet-mold them to perfect squares. I make different sizes and I got sick of pulling out the table saw. I found something better. Target has a version of the Jenga game...small identical wooden blocks. I creatively place them inside and make it tight with scrap leather. Another benefit is that they aren't as difficult to remove as a form. Remove one from the center and they all come out easily. I told my wife I'm an genius...she's still skeptical. Quote Actually...it is rocket science.
Members Nuttish Posted June 6, 2014 Members Report Posted June 6, 2014 I would suggest picking up a copy of the Leatherworking Handbook by Valerie Michael. Ignore the creepy masks. They're just weird. She's got a section on the butt stitch and box stitch. The box stitch is the traditional stitch used for boxes and tubes. The butt stitch is the traditional stitch used for joining pieces of leather in the same dimension. Quote
Members mtroyalguy Posted June 6, 2014 Members Report Posted June 6, 2014 The block trick is the same trick milners use to make shaped hats with smaller brims than crowns. They make a form the right shape out of wood and cut it into several pieces, usually 6 using # custs. When the center block is removed the other pieces can then be removed easily, keeping the shape of the hat. Quote
Members WyomingSlick Posted June 7, 2014 Members Report Posted June 7, 2014 I make a lot of boxes with mitered and sewn corners. I normally make wooden forms to wet-mold them to perfect squares. I make different sizes and I got sick of pulling out the table saw. I found something better. Target has a version of the Jenga game...small identical wooden blocks. I creatively place them inside and make it tight with scrap leather. Another benefit is that they aren't as difficult to remove as a form. Remove one from the center and they all come out easily. I told my wife I'm an genius...she's still skeptical. LEGO blocks work well also Quote (John 8:32) And ye shall know the truth, and the truth shall make you free. (KJV) And the truth is that religion is nothing more than the lame attempt by largely ignorant people to bring sense and order to a world that was beyond their comprehension. Once you see religion for the delusional and superstitious artifact it is............... you will be free !
Members WScott Posted June 8, 2014 Members Report Posted June 8, 2014 Like to see some pics of your boxes Nothing in your gallery Quote
