Members Albannach Posted July 3, 2018 Members Report Posted July 3, 2018 Thanks a lot Constabulary for the updated link, it was just what I was looking for. It's nice to have the manual for my singer 133k10 now as in the near future I want to learn how to use it. Quote
Members Amr Posted December 25, 2019 Members Report Posted December 25, 2019 Thanks for information Quote
Members AlexandreP Posted April 4, 2020 Members Report Posted April 4, 2020 On 10/13/2014 at 8:14 PM, Constabulary said: Was a busy sewing machine weekend - I`m finally done with my 133K3 setup. Got the Jack servo motor last weeks and puzzled everything together now. I will add smaller 40mm pulleys to my motors but its working well already. The 133K goes through 12mm stiff webbing but it needs some speed but it works! The 2 machines under the table can be switched with the 2 mounted machines. But I have to make a small frame for the 29K73 so I can use the same wing screws to mount it on the table. How could i make the same to a 133k8 i´m interested right now? Could you say what tools did you use as well the mechanical restoration you did? Also could you inform how it is to work with this machine ( what type of projects do you sew with it, the lenght of the stitch, etc). Is it easy to find spare parts to this machine, and does it cause too muchh trouble? Quote
Members Constabulary Posted April 5, 2020 Author Members Report Posted April 5, 2020 (edited) I have been sewing webbing with it but I replaced the machine with a Singer 45D91. I usually have sewn with 4-6mm stitch length. Regarding tools - well it basically was a couple of screw drivers. I cleaned the internal mechanics with paint thinner. Spare parts you find galore at College Sewing in the UK: https://www.college-sewing.co.uk/parts-by-machine/singer-sewing-machine-parts/singer-132b-132k-133k-parts Seiko SK-2 and Mitsubishi DY253 are similar and share a lot of parts. Mechanically... well I replaced a few parts like check spring, bobbin case retainer spring and feed dog the rest was cleaning, painting and needle / hook timing and smaller adjustments here and there. If you want to restore your machine please open a new thread for it. Check this thread there is a manual for the 132K6 flat bed version linked but the needle /hook timing values are the same as for the 133K8 cylinder machine. Edited April 5, 2020 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members AlexandreP Posted April 8, 2020 Members Report Posted April 8, 2020 On 4/5/2020 at 8:29 AM, Constabulary said: I have been sewing webbing with it but I replaced the machine with a Singer 45D91. I usually have sewn with 4-6mm stitch length. Regarding tools - well it basically was a couple of screw drivers. I cleaned the internal mechanics with paint thinner. Spare parts you find galore at College Sewing in the UK: https://www.college-sewing.co.uk/parts-by-machine/singer-sewing-machine-parts/singer-132b-132k-133k-parts Seiko SK-2 and Mitsubishi DY253 are similar and share a lot of parts. Mechanically... well I replaced a few parts like check spring, bobbin case retainer spring and feed dog the rest was cleaning, painting and needle / hook timing and smaller adjustments here and there. If you want to restore your machine please open a new thread for it. Check this thread there is a manual for the 132K6 flat bed version linked but the needle /hook timing values are the same as for the 133K8 cylinder machine. Ok. Nice info. Thanks Quote
