Members Leerwerker Posted November 8, 2008 Members Report Posted November 8, 2008 One of the very first pages I discovered on the internet in the early nineties (before there were graphics on the web), was a definitive page about Cuir Bouilli by Marc I Carlson - You can still read it at: http://www.personal.utulsa.edu/~marc-carlson/leather/hl.html Marc's other page about leather is at http://www.personal.utulsa.edu/~marc-carls...ther/leath.html These are pages to bookmark! Quote JOhan ------------------------------------------- ****Afrikaans: Leerwerker ***** ****Zulu: lesikhumba isisebenzi Latvian: ādas darba ņēmējs *****Russian: кожа работника ****English: Leatherworker ****Dutch: Lederbewerker ****Flemish: Leerbewerker ****Hebrew: עור פועל ****German: Leder Handwerker ****Hungarian: Bőrdíszműves ****Turkish: deri işçisi ****French: Artisan du Cuir ****Spanish: Artesano de Cuero ****Norwegian: Skinn kunstners ****Swedish: Läderhantverkare ****Greek: δερμάτινα εργαζόμενος Sotho: mosebeletsi oa letlalo
Members Happycrow Posted November 8, 2008 Members Report Posted November 8, 2008 TwinOaks, that's one of the best descriptions I've seen. I've done a lot of experimentation on this score (though, sadly, my skills as a craftsman are poor: too many publications, too little actual work!), and the toughest bar-none leather we've seen treated this way was a half-tanned leather (meaning, it was not allowed to sit long enough for the tannings to penetrate all the way into the leather, resulting in a pure-rawhide core -- I prefer salt-soaking when I do this to discourage the buggies), which was then hot-stuffed with hide glue and baked wet at 170. There are LOTS of variations, and I've seen descriptions of hot pitch being used as well, both in experimentation and in a couple historical records (steppe sorts essentially making leather jawshan) Quote
Members RuehlLeatherWorks Posted November 23, 2008 Author Members Report Posted November 23, 2008 A modified 2-piece pattern from www.armorarchive.org. After making this one I had to tweak the pattern a bit since leather works a bit differently than steel. Anyway, 10 Oz hardened leather with a 6 oz 'joint'. Aluminum double cap rivets and grommets. Laced with Deerhide. Quote
Members Daggrim Posted November 24, 2008 Members Report Posted November 24, 2008 I've had lots of experience with Cuir Bouilli, since every helmet I make is treated to harden the leather. I just use the hot water, and the leather is 10 to 13 oz saddle skirting. The procedure is very time and temperature critical. I aim for a water temp of 175 to 180 degrees, and the immersion time varies from 2 to 3 minutes. A difference of just 5 degrees can cut your time in half, or double it, so you need to watch closely. I pull it out for inspection every 30 seconds or so. As you treat more pieces, the water turns dark red, and you can't see the leather. I presoak the peices in room temp water, because if they go in dry, the thermal shock will just shrivel them. Do not allow the peices to touch the pot, it'll make hot spots, and shrivel it there. I use a folding round vegetable steamer in the pot to isolate the leather. Water at 170 will have some hardening effect, but you'll need to leave it in there for maybe 4 minutes, and it'll never get really, really hard. It'll dry more like heavy cardboard than armour. If you start with stiff leather, it hardens very well, and if you start with floppy leather, it'll also never get really hard. When the leather starts to turn dark...get it out asap, because that's the point when it starts to shrivel. Leather brought to that point gets super hard. The flesh side dries like sandpaper, and the edges have just begun to curl. I've hardened 8 oz leather, but it's tricky. You can't fudge on the temp...hit it with the full monty...175 degrees, but watch it like a hawk. Itll start to shrink earlier than heavier leather, and so you might need to do some tugging to reshape it. You have about 30 seconds to get the leather into a mold after you pull it. It's gonna be rubbery, so be careful or you can distort it with careless handling. It'll start to set up in about 15 minutes, and then you can moderately shape it for about an hour. I've taken pieces that never got hard enough, and resoaked them, them dried them in the oven at 200 degrees. They kinda flatten out and sag, but you can reshape them. I leave them in for 30 or 40 minutes. They scorch where they touch the pan, or the screen. So, there it is...way more than you asked for. I read lotsa stuff on the internet when learning this technique, and I took the parts that made the most sense to me. I'm also a little lazy, so I always try to K.I.S.S. a job as much as possible. I hate the Fuss Factor, and try to cut it out of all my processes. And lastly, the temps are what I see on my candy thermometer, so there might be variations with your thermometer. Hope this summary can help someone. Daggrim Quote
Members Rattlesnake Posted January 14, 2009 Members Report Posted January 14, 2009 Servus! I've had very good experience in soaking the leather and then putting it in the oven at a low temp. The advantage of this is that the temp is far easier to control than water on the stove and you can easily take things our and reshape as time goes on. The effect - driving out the tannins - is the same A really great tutorial could be found at the House of the Wolf website but he's gone out of business and no longer maintains the site. I have a copy of this on my drive - I'll ask Dan if I can reprint it here. Quote Pax Vobiscum, Rattlesnake Jake
Members Peter Ellis Posted March 31, 2009 Members Report Posted March 31, 2009 Servus!I've had very good experience in soaking the leather and then putting it in the oven at a low temp. The advantage of this is that the temp is far easier to control than water on the stove and you can easily take things our and reshape as time goes on. The effect - driving out the tannins - is the same A really great tutorial could be found at the House of the Wolf website but he's gone out of business and no longer maintains the site. I have a copy of this on my drive - I'll ask Dan if I can reprint it here. I agree that Dan gave an excellent tutorial on a very consistent and reliable method of producing hardened leather. Marc Carlson's webpages (mentioned earlier in this thread) give a good introduction to the chemistry involved and the temperatures required. I'll second the observation made earlier regarding halftanned leather and hardening. I did an elbow cop from halftanned (about 12 oz or so) and was amazed at its toughness and resiliency. I could actually turn it inside out and pop it back into shape without cracking, yet it was hard... The historical records regarding use of wax and pitch appear to be related to making leather waterproof. There are records describing in great detail a French process for "jacking" boots, involving wax. Quote Peter Ellis Noble Lion Leather
Members lokiprime Posted April 28, 2009 Members Report Posted April 28, 2009 I made a breast plate in the past and I used a 50/50 mix of bees wax and carnuba wax. This made it rock hard. you do not boil it. you heat the materials up close to the flashing point. Not sure how long I left in, too many years ago. Then I took it out and placed it on my chest. ( I was wearing gloves and had a couple of heavy sweatshirts on) Then I had someone ice it down... This kept the form.. Enjoy... Quote "May the wind be at yer back and the sun never in your eyes!" "Hail and well met!" Lokiprime
