Available at Home Depot for < $5 and works great with oil dyes.
Cya!
Bob
How was this applied?
The first thing noticable is that the streaks all run horizontal. If you're using a dauber - stop. Use a piece of sheepswool. Apply liberally in a CIRCULAR fashion.
Better yet, first left to right, then up and down, then in a circular fashion. This gives a very good application and it will aborb more evenly than just one direction.
Cheers!
"Out of my mind.....back in 5 minutes"
I've seen a few people use wool in videos. I'm starting to get tempted to try it. Approximately what size of piece is recommended for dyes/finishes?
Just any cutoff would work. 2x2". If you don't have that use an old t-shirt. Cut a good size piece, ball it up and use another piece of the tshirt to wrap around it and tie off. Now you have a pad that will work. Other materials would work as well. The key is that it lets you apply a liberal amound of dye and that you get good coverage.
Cheers!
Additional:
Here is a link to the Evil Empire's site that shows a video of a good application of the water stains. This would work fine for the oil-dyes too.
Edited by Studio-N
Thanks for the great replies all. Had to apply several coats to finally get the streaks to even out (now dark brown instead of light). BDAZ, I think I might try the Preval sprayer for the next project--good advice.
I second dip dying...very easy and quick...saddle tan comes out very good each time. The dye also goes deeper into the leather. Just my 2 cents.
Troy
Imler's Leather
Bentonville, VA 22610
http://www.ebay.com/usr/imlers_leather
Cheers!
Additional:
Thanks! I'll pick up a pack of remnants and try it out.
http://www.cgleathercraft.com
Member of the Iron Brigade.
