I am looking for a complete bolt-on gearbox for a Singer long arm, large bobbin patcher. My patcher is model 29k172 (blue body). The gearbox bolts onto the left side of the free arm and contains the shuttle, which drives the bobbin case. It should contain the shuttle, both pinion gears, long and short rack gears, throat plate springs and top and bottom cover plates and it should operate freely, without binding, nor with too much slack in the shuttle driver.
So far, all I've found online are for small bobbin patchers. Mine uses the large bobbin and bobbin case.
Contact me on the form, via a private message if you can sell me one.
Posted IMHO, by Wiz
  • 2 weeks later...
are still interested in one complete gear b
ox for 29k72 big bobbin I have one thank you
Yes, I am still looking for a gear box for a Singer large bobbin, long arm patcher. Please send me a PM with the details.
Posted IMHO, by Wiz
The gear box that I got is brand-new it's got everything except the needle plate and mine is 29k72 I'm asking 250 for it thank you
$250, with no needle plate? Really? What happened to the plate? What about the stud that holds the plate down and locator pin?
Posted IMHO, by Wiz
The Stud is there the pin with that little spring the Shuttle carrier hook carrier two little pinions gears two bar gears the small one an the long one and the gear box and all the Parts got their number and it said simanco something like that The needle plate was not in there I bought a singer 29k60 long arm big bobbin and they gave me the gear box thank you
Okay, thanks. That is more than I care to spend on a backup gearbox.
Posted IMHO, by Wiz
