Members Kansan Posted September 19, 2014 Members Report Posted September 19, 2014 I'm making an old style US Army cavalry holster for a 1911 pistol. It has a 3" belt loop on it since this style of holster is a thigh holster. I probably shouldn't have, but I dyed the inside as well as the outside of the belt loop piece. I used Fiebings professional oil dye, so it shouldn't run too much, but I am concerned that the dye will run a bit. The interior of the belt loop will have a leather belt, obviously, rubbing against it and the belt could even potentially be wet with sweat on occasion. So, prior to final assembly, I'm considering finishing the inside (rough side) of the belt loop with either resolene or just slicking it all with gum tragacanth to really seal it and preventing any dye from bleeding. Is this the best way? Any other ideas? Quote
Members Dwight Posted September 19, 2014 Members Report Posted September 19, 2014 When I get in a pickle like that, . . . a wool dauber, . . . resolene, . . . finishes off the pickle. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Members Kansan Posted September 19, 2014 Author Members Report Posted September 19, 2014 Ok, thanks. I think that's what I'll do. Sometimes I forget to think the whole project through before charging forward on different parts. Life and learn... Quote
Members silverwingit Posted September 20, 2014 Members Report Posted September 20, 2014 FWIW, I'd slick the flesh side down with Tan Kote or Bag Kote and then seal it with Resolene. I don't think Resolene by itself will slick the flesh down well enough. Michelle Quote
Members Kansan Posted September 20, 2014 Author Members Report Posted September 20, 2014 Thanks, Michelle for the suggestion. It's too late now, as I just put resolene on it. I'll see how it works. You're probably right that two layers of something (Tan Kote + Resolene) would probably have slicked it more. I'm the only person who will actually use it, so if the dye bleeds it will fit in with all the other dye stains I usually have on my clothes Quote
