I have been experimenting with fabricating my own patterns, and I decided to share the pattern I like best.
I am fairly new to leatherwork, because of that I like to keep things as simple as possible. In the plan i specify where to sew and where I put rivets (Rivets are not necessary though, you could just sew it). It is all cut with one piece of leather, which is what I wanted.
This pattern is for an open top design for easy access to your drink. You could easily add a strap and a snap over the top of the flask though if you felt so inclined.
Also, please note the thickness of your leather! I failed to account for this in my first version and it was a pain to get the flask to fit nicely.
Edit - The pattern should work now, Sorry about that guys.
Flaskbig1.pdf
Edited by xStarkweather
Thanks for the pattern, unfortunately I tried downloading it twice and it was blank?
Yea, I just looked at it too, same thing. That is weird, but its my first time trying to convert an Inkscape document to a PDF. Gimme a sec, I will try to get it up and running.
worked fine for me
Thanks
Thank you for sharing.
Crooked Finger Leather
5514 E. Hwy 40
Greenfield, IN 46140
(317) 947-8046
Thank you for sharing your pattern and hard work.
Greetings from Central Texas!
The Grain Side Up blog
#TheGrainSideUp
Can you or someone who has already used the pattern show what it looks like completed I'm having a hard tim visualizing it.
Yea, I was going to edit the first post, but I guess I can't.
I ended up adding a security strap over the top as well.
Back view
