  • 2 weeks later...
  • Replies 32
  • Created
  • Last Reply
Top Posters In This Topic
Hello 4wheeler,
Have you tried Ohio Travel Bag?
I do know that they carry a 3/16" eyelet wit 7/32" flange depth. I will look around and see if I can come up with something. I have seen them but not having need at the time I did not save the information.
God Bless.
Ray
4wheeler,
Take a look at romefast.com. They have a selection of various sizes.
God Bless.
Ray
Hello 4wheeler,
God Bless.
Ray
Ray,
Thanks for your response. Ohio Travel Bag was one of the first stops that I made as they have delivered unusual finds for me in the past. The leather belts are 1/4 inch thick and the customer wants grommets or eyelets that will go all the way through.. They will not compromise on the belt thickness so I am still searching for a better solution.
Best wishes!!!
i just happened to go on the tandy website. they have what's called long post grommets. they are 1/4" if you skive slightly around the grommet post, this would probably work for you. tandy!....who knew?
Thanks to all who responded to this request. Yes, I was finally able to obtain some from a knife and sheath maker who purchased them bulk from the manufacturer. Just to make things clear, what I needed was eyelets that would go through three layers of leather. The hole in the eyelet could be either 3/16 or 1/4", I didnt care. I ended up w some 1/4" which works great. I hesitate to mention my source for these eyelets since they are not in the parts and pieces business and I would not want to be the cause of a deluge of requests to them for eyelets.
Again, thanks to all who pitched in to help!
Hi Ramrod,
Thanks for the response, I have tried several packages of the long shank from Tandy. The shank is 1/4 " but it is not 1/4" under the flange. Skiving around the hole is not applicable in this circumstance. I thank you for the info sir!!!
http://www.speedpress.com/products/2/46
Try this and see if it is what you need.
Thanks Geneva,
Those grommets do not have the length under flange to consistently go through 1/4" material. Thanks for your input
i HAVE seen a website that did offer longer shank grommets. it's frustrating that i ca't think of where i saw it. i usually put it in favorites immediately. must let that one slip by.
