Members Blanket Posted October 27, 2014 Members Report Posted October 27, 2014 (edited) Hi all, Need your help again please. I am very new to sewing machine, I found this Pfaff 335 online: http://www.valesew.co.uk I contacted the seller and was told that the machine is brand new. I am wondering if you can advise me what subclass this is, and tip on how to check if the machines are genuinely made not a counterfeit or used. How could I check that? Also where can I find technical info on this machine? I downloaded a leaflet but it doesn't say much sadly. I told the seller that I am planning to sew 3/8" max (veg tan leather + fabric) he doesn't seem to think it will take that thickness? Many thanks! Edited October 27, 2014 by Blanket Quote
Members ThomasK Posted October 27, 2014 Members Report Posted October 27, 2014 (edited) You can find the Informationes you need on www.pfaff-industrial.de Which subclass it is will Standing on a label on the backside of the machine. If it´s an original, you normaly will find written " PFAFF", and a number (sparepart number) on most single part of the machine. If you need more Information you can send me a private mail, so I can attache you some PDF files Greetings Dieter 335_e.pdfFetching info... Edited October 27, 2014 by ThomasK Quote
Members Blanket Posted October 27, 2014 Author Members Report Posted October 27, 2014 Thank you Dieter. I will try to see if I can get this from the seller Quote
