Dan,
I punch all my holes just before I start sewing. I rarely have a problem with them closing up. Like Lobo, I use a drill press on most of my projects, but I use a very small drill bit to actually drill a small hole in the leather..... Occasionally I will use a sewing awl, but I still punch the holes first with the blade from the awl before I sew them. I imagine if you wait long enough after punching the holes, that they could close up... but I don't give them a chance. Most of my projects are not so large as for time to be a factor in the sewing of pre-punched holes.
-Tac
"Well, I guess we did our good deed for the day Mayor"-Wyatt Earp "Tombstone"
Pete...
Here is a pick of my burnishing wheel set up. It's the slicker wheel from Tandy mounted on a bolt so it can be chucked in my drill press.
http://i83.photobucket.com/albums/j296/Tac56/100_0880.jpg
http://i83.photobucket.com/albums/j296/Tac56/100_0881.jpg
Let me know if you have any questions.
-Tac
So drill all the holes and then go back like normal with sewing awl and needles. Only the awl only has to cut the sides a bit rather than punching the hole. Is that right? Still sounds like it could be a winner. I'll give it a try.
Dan
Dan,
It depends mostly on the thickness of the thread I am using. Most of my projects I can get away with just drilling the holes on the drill press, with no need for the awl. If the leather is thick and the thread I am using is heavy, then using the awl after the drill press can help make sewing easier. Most of my holsters are made with a double thickness of 7/8 oz. leather in the areas that are sewn, and I just use the drill press for the holes.
-Tac
I have used that drilling method myself. It gave me the best looking hand stitch job I have done to date. Very nice and easy to maintain a good straight even sewing pattern.
Pete,
Nice holster, good job!
One quick tip, don't mold behind the trigger. You don't want a mishap when holstering the weapon.
-bob
Picture one
Picture two
Thanks for the tip! I have wondered about that... Good thing the Makarov has the heaviest trigger known to man. :)
LOL :rolleyes:
-bob
LOL :rolleyes:
-bob
Actually I take that back, the double action pull on my Sig P225/P6 was worse until I did a trigger job on it. :)
