This is a new machine, and I thought Toledo would have dialed it in better. Am I being too picky, or do you see something wrong as well?
post-35312-0-99287100-1418797524_thumb.j
Edited by RoosterShooter
That's not too bad. Just back off the top tensioner a half turn and see if the knots drop down a little more between the layers.
When you received the machine, how thick was the stack of sewn off leather under the foot?
Was it sewn off with the same needle and thread as you used in your example?
Posted IMHO, by Wiz
If your machine was setup to place the knots in the center of a 1/2 inch stack, when you sew a 1/4 inch stack the knots would be too high with the same tension adjustments, thread and needle.
Posted IMHO, by Wiz
FYI: Most of us with big sewing machines will run test stitches every time we change thickness, leather, thread, or needles. If I'm edge sewing into a belt that is skived on the buckle end, I back off the top tension a turn until I reach the full 10 - 12 ounce area. Then I add that tension back and continue around the belt, until I reach the thin end on the flip flop. Back off a tad and stitch over the first 3 or 4 stitches. Much of this is done by feel, visual inspection after x many inches, and just getting used to your machine and the thread.
Posted IMHO, by Wiz
That makes sense.
Mine was set up using a double stack 8 oz. Latigo. So, 16 oz of leather with a good looking stitch from the dealer.
I'm using a 7 oz. on the top and a 4 oz. on the bottom. So, roughly 11 oz. Veg Tan with a soft 'hand' to it.
That makes sense. I'll turn her down a tad and see if that fixes it.
As always ... I can count on you for help Wizcrafts
That makes sense.
I'm using a 7 oz. on the top and a 4 oz. on the bottom. So, roughly 11 oz. Veg Tan with a soft feel to it.
I'm your huckleberry.
Posted IMHO, by Wiz
