I have acquired a used consew 227. The problem is bottom thread has always been loose/looping. I have tried adjusting the tension on bobbin/taking out bobbin and removing debris ect. Upon removing many parts i do notice the needle is hitting the bobin case on its way down. Pretty sure this is not a good thing. Please help
  • Replies 23
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Is the needle hitting the hook "hard" and you cannot sew or is it deflecting the needle or is just the hook tip touching the needle?
its always a good idea to post some pictures or a video of what is going wrong. Most likely your timing is off or you have insert the the needle in a wrong angle.
Edited by Constabulary
the needle appears to just nick the hook then as it lowers some more it hits the bobbin case and you can see the needle bend a bit.
i have pics and video but not sure how to post vid.
i have to resize pic first as well.
thanks for the response.
in the lower right corner is a brown button "MORE REPLAY OPTIONS" there you can upload the files.
I would assume you just have to adjust the needle bar a little bit.
Check if you have insert your needle correctly. The needle scarf has to face exactly right (towards the hook). When you turn the hand wheel the hook tip has to meet the needle scarf about 1.6mm above the needle eye.
Thank you so much for your replies and help. I want this machine to stitch perfectly, even if i have to repkace it piece by piece! Heres a pic. The needle just barely bends and hits casing. The needle bar?/holder looks a bit banged up too. Maybe i should replace thus before messing with timing.
sorry - no pictures...
That is the needle deflector, you can carefully adjust it / bend a tiny bit but be really carefull!!!!
But before you do that check if the hook tip meets the needle scarf ~ 1.6mm above the needle eye when the needle bar is on the upwards stroke.
BTW - your hook tip is broken or blunt as it seems but I´m not sure it just looks like.
i just checked.
on upward motion the hook makes contact with the scarf right around that 1.6 mark.
is the needle supposed to make contact with the hook and that deflector below the hook like that??
