whats the best match for a 4" colt python in a dummy gun I see not to be able to find one??
Ray cast this one from the 6" python, but if he's not carrying it any more, the smith L-frame is VERY close in TOTAL size. I make a hip holster that fits both pretty well. If however you are molding the holster, that rib down the top of the python changes all of that.
Edited by JLSleather
There are three production revolvers that share similar profiles and dimensions: Colt Python, S&W L-frame, Ruger GP100. These revolvers are not identical, but quite similar.
If you are making a closely formed holster the actual model is required. For a more general fit it is possible to use these 3 interchangeably to some degree, with some caveats:
1. Fit will not be "perfect". The handgun will shift around in the holster to some degree during normal body movements during use, bringing the likelihood of accelerated holster wear to the handgun finish (not a small issue, particularly with the pricey Colt Pythons).
2. Of the 3 the largest frame dimensions will be found on the GP100, particularly at the top strap and rear sight areas. A holster formed on the GP100 is likely to accept the S&W L-frame or Colt Python, while the reverse is less likely to work.
3. While overall profiles and dimensions are close, the actual dimensions and locations of key features (such as cylinder, trigger guard, etc) are measurably different, and these can affect both fit and function of a holster.
4. The long hammer spur of the Colt Python will require considerably more clearance in a holster with thumb-break retention. Without having one on hand for patterning and forming it will be difficult to achieve a good result.
Best regards.
So, like this one then?
