Hello folks, some of you may have heard about the tool I have made in collaboration with Justwood over here in the UK.
It is a burnisher designed to fit a standard bench grinder that has a 1/2 inch shaft (12.7mm)
This is a burnisher with a difference as it is designed not to crush the corners of the leather but more to offer an even pressure to the whole edge giving a stronger and more natural profile.
you can get the burnisher directly from Just Wood, just follow the link: http://www.justwood.com/buy/nigel-armitage-just-wood-leather-burnisher_30.htm
and you can see it at work here: https://youtu.be/g9aC1BSMOpQ
Regards
Nigel
Armitage Leather
www.armitageleather.com
Edited by Dangerous Beans
The secret to creativity is knowing how to hide your sources.
I have purchased Nigel's burnisher. It is very well made. It is expensive and to ship to the US. It does works very well and do I like the design!
It mounted to my polisher with no problems. So far so good. It is a tool that will get a lot of use.
Thanks,
Phill
