AlexLeather Report post Posted April 24, 2015 I ordered these conchos online from an italian supplier. They arrived without any other hardware. How do I attach these to a belt ? Quote Share this post Link to post Share on other sites
TexasLady Report post Posted April 24, 2015 (edited) Hi Alex. I just stumbled upon your post. I contemplated it for a couple of minutes and then almost started to laugh. I think you got 'took'. I hope the front sides of the conchos are pretty enough to be worth all the work you'll probably have to put into salvaging them and making them usable. I found this website online where they talk about soldering pins or wires to the back of conchos. http://www.riorondo.com/hardware/conchos.html Edited April 24, 2015 by TexasLady Quote Share this post Link to post Share on other sites
cgleathercraft Report post Posted April 24, 2015 I've heard of thumb tacks being soldered onto the back of conchos then bending the pin over on the back side of the leather. Slip a tiny flat washer under the pin and solder the bent pin to the washer. If your comfortable with a soldering iron it should hold just fine. The one i saw was a lapel pin re-purposed to go on a keychain and looked pretty good! Quote Share this post Link to post Share on other sites
TLP Report post Posted April 25, 2015 If It was me I would trim the post on the back to slightly longer then the width of the leather and the thickness of a suitable copper washer, (washer inside diameter should be a very snug fit) then rivet the whole works together, you will be peening the post down so that it mushrooms and will no longer fit through the rivet. The conchos you bought appear to have been cast and the person doing the casting extended the post on the back of the concho during the casting process to provide a channel for the metal to be poured into the mold. Quote Share this post Link to post Share on other sites
AlexLeather Report post Posted April 27, 2015 UPDATE: I've heard back from the supplier and they've instructed me how to do it. Here is the copy/paste reply for anyone who runs into this problem themselves: "1) firstly to fix better the studs on the leather you need backrondels bought in a normal hardware shop, the rondel holes should have the same size of the stud spike. 2) put the studs in the leather hole and block on the back with the rondels, cut the stud spike just leaving the rondels going 1/2 millimeters out of the rondel hole 3) hammer on the spike edge like the hours of the clock, enlarging the head of the spike so it will be larger than the hole and it will not come out anymore 4) if you have difficulties you can make the brass softer almost like tin putting the studs on the fire for few mins an leave them cold down naturally at ambient temperature" Quote Share this post Link to post Share on other sites
TexasLady Report post Posted April 27, 2015 (edited) Thanks for updating us, Alex. What I still wonder though is if you won't need to grind off some of the irregularities before attempting to follow those instructions. Edited April 27, 2015 by TexasLady Quote Share this post Link to post Share on other sites
wildthings Report post Posted April 28, 2015 What is a backrondel? Quote Share this post Link to post Share on other sites
AlexLeather Report post Posted April 28, 2015 I would guess a washer, wildthings Quote Share this post Link to post Share on other sites
Sluggo001 Report post Posted April 28, 2015 I've peened over post conchos and you'll need a copper washer and a lot of patience. If they aren't mostly silver, the posts will be brittle and the edges will chip off. Take your time Quote Share this post Link to post Share on other sites
Grey Drakkon Report post Posted April 28, 2015 Annealing the shaft (putting it in fire until it just barely glows, then letting it cool down slowly like they instructed) will soften up the metal and help avoid chipping. Quote Share this post Link to post Share on other sites
