I had a problem with thread on my machine and somehow poked a small hole where one shouldn't be. It is only through the top layer of a brown holster.
What is the best way to fix it, it there is one?
I have occasional poked a hole where it should not be. I use a diamond awl and find after a while a considerable amount of the hole heals up. I take the tip of my awl handle (which is round) and kind of push and rub the hole ares this also helps close the hole. dye it the rub a little bees was into the hole If any hole is still apparent. Doing all of this it should pretty much disappear.
Edited by camano ridge
What about a little bit of Tandy Leathercraft Cement dyed brown, then rubbed into the hole?
