Members abosely Posted May 15, 2015 Members Report Posted May 15, 2015 (edited) Hey all, could I get some help narrowing down what models to look at of older cylinder, compound feed with reverse machines? For sewing heavy canvas duffel bags and such things. Max foot height of 3/8" would be fine, don't really need 1/2" if that makes a difference. There's a lot of variations to try and figure out which models or sub-models have what. I've been trying to do my own research, but still pretty clueless. After reading some more I thought I should mention that if an older sewing machine isn't going to have reverse, can I use the hand crank to reverse sew enough to lock the stitch? Cheers, Allen Edited May 15, 2015 by abosely Quote
Members Constabulary Posted May 16, 2015 Members Report Posted May 16, 2015 Pfaff 335, 345 and Adler 69, 169, have all reverse. Consew 227 came with and without reverse (the ones marked with "R" have reverse). The Singer 153 is the only one (afaik) that never came with reverse. Then SEIKO, JUKI and so forth also made a similar model (don´t know all the model names). These are the most common ones you´ll find in used condition. Most machines have subclasses the subclass describes features that certain machines have. There are of course many other brands (most are Chinese made clones of the Consew 227R) like Techsew 2700, Cowboy CB227R, Artisan... Generally spoken non of the above machines are bad - it of course depends on their condition and how the machine is set up. Buying a used machine can be a gamble but you also can have a lot of luck. I have bought all my machines used and all are working very well but they all needed some TLC After reading some more I thought I should mention that if an older sewing machine isn't going to have reverse, can I use the hand crank to reverse sew enough to lock the stitch? Well, there is a "Poor Mans Reverse" for machine w/o reverse sewing function. Just turn the work around and sew backwards. Or lift the foot and pull the work forward one or two stitches lower the needle into a hole one or two stitches back and sew forward again. But a machine with reverse is much more comfortable. Keep in mind that you sometimes have sewing situations where you can´t turn around the work f.i. when sewing close to hardware or so. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Moderator Wizcrafts Posted May 16, 2015 Moderator Report Posted May 16, 2015 The older the machine, the less likely it is to have reverse. And no, you cannot reverse wheel the machine to sew backwards. If you want a cylinder arm machine with reverse, buy something more recent (last five years or so). A Consew 227R, or clone, is exactly what you are looking for. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Darren Brosowski Posted May 17, 2015 Members Report Posted May 17, 2015 It really comes down to the condition of the machine. If we were talking about an old school Singer or ADLER then they will probably run for another 100 years but newer machines were set up for higher speeds and have much higher wear rates. Unless you are buying a machine from a dealer you trust and will warrant a second hand machine then it is probably cheaper to buy a new version fully set up with a servo motor. Quote
Members Yehdhdh Posted March 9, 2025 Members Report Posted March 9, 2025 Hi. Thanks! with older electric motors usually it’s possible to reverse polarity and the motor will run backwards. Anyone see any problems with having a polarity switch? Quote
Moderator Wizcrafts Posted March 9, 2025 Moderator Report Posted March 9, 2025 8 minutes ago, Yehdhdh said: Hi. Thanks! with older electric motors usually it’s possible to reverse polarity and the motor will run backwards. Anyone see any problems with having a polarity switch? The problem with reversing the motor is that if the hook runs backwards, it won't pick up the thread loop off the needle. Sewing machine shuttles pick off in one direction only. To reverse the feed, the machine needs to be designed to reverse the direction of the feed dog and anything else that moves in sync with it. In the case of walking foot machines, there are 3 things that need to reverse: the feed dog, then needle bar and the inside foot. For bottom feed machines with a fixed foot and needle, only the feed dog needs to reverse. You cannot add this onto an existing machine. If you want a machine to reverse, buy one that already has a reverse lever. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
