Members RememberingGS Posted May 19, 2015 Members Report Posted May 19, 2015 Hi guys and gals. I really wanna try and make a motorcycle seat using my stock 2003 vtx1800c seat. What,be easiest way,to go about this. I made a fork tool bag that came out pretty nice and I wanna try a seat. Any pointers or does anyone have a pattern. I really appreciate it. Quote
Members Horseshoe Posted June 7, 2015 Members Report Posted June 7, 2015 Carefully take the covering that is on the seat now and use that for a pattern. If it is covered with one piece of vinyl that has been stretched over the padding that may not work so well. I doubt you will find a pattern that is already made for your seat, you'll most likely have to make one. Read some of the pinned posts in this section they go over how to make a pattern, he's making a solo seat but with some thinking you should be able to adapt the idea to your seat. Good luck. Quote
Moderator Art Posted June 7, 2015 Moderator Report Posted June 7, 2015 Hi guys and gals. I really wanna try and make a motorcycle seat using my stock 2003 vtx1800c seat. What,be easiest way,to go about this. I made a fork tool bag that came out pretty nice and I wanna try a seat. Any pointers or does anyone have a pattern. I really appreciate it. If that's the seat I am thinking of, there are four or five panels to it, you better hope you can get the cover off to make a pattern. The old lady part (if I remember correctly) you can just do a one piece cover on. The other thing you might think of doing is taking the seat off and building a seat pan (it will give you a lower ride if you can take that). It isn't as hard as it sounds and if you have a little skill, you can spring it or even put a shock in because there will probably be plenty of room where the old seat lived. Then you will always have the old seat if your first attempt comes up short. I don't know what kind of riding you do, but if you like to do long rides, a chopper style seat mount (like right to the frame) will have you pissing blood by the time you get there. Art Quote For heaven's sakes pilgrim, make yourself a strop!
