I want to use my air brush to spray on the top finish so the dye is not wiped off when using a sponge. Do you spray it straight or does it need to be diluted with water? If so, what is the percentages?
I would dilute them 50/50 with water and apply lights coats allowing either sheens to dry in between coats. I tried and don't like either sheen. Switched to resolene diluted 50/50 and now use mop and glo diluted 50/50. Any of these can be built up to get the look you want.
