Members Nuttish Posted July 7, 2015 Members Report Posted July 7, 2015 What's wrong with a traditional angled skiving knife? Bell knife skivers are expensive and have a steep learning curve. Lisa Sorrel's Japanese knives are cheap and quite nice. Quote
Members mrtreat32 Posted July 7, 2015 Members Report Posted July 7, 2015 thanks andrewchee with your feedback on the scahrf fix. I'm surprised to hear that since book binders seem to love it. Quote
Members DavidL Posted July 7, 2015 Members Report Posted July 7, 2015 bell skivers are that hard to get right? I would imagine hand skiving would be harder, just the sharpening itself is one year learning curve. I only hand skive right now but always thought bell skiving machines were on the easier side. Quote
Members lilwaysleather Posted October 18, 2015 Members Report Posted October 18, 2015 Don't get a scharf fix. I got one a while ago to do this and it cut through the leather all the time. Not easy to use. I ended up getting a bell knife skiver and I think it only cost me about $600-650. Not cheap but much better results. Andrew where did you get your bell knife skiver? Is it fairly easy to use? Quote
Members Andrew Chee Posted October 18, 2015 Members Report Posted October 18, 2015 I got mine used from cobra Steve. Look around and your u can find them used for a decent price. They aren't that complicated but there's definitely a learning curve. I can answer any specific questions you have about use. Andrew Quote
Members lilwaysleather Posted October 19, 2015 Members Report Posted October 19, 2015 Thanks. Which kind did you get? I heard that they are always needing adjusting to get them working right. has that been your experience ? Also wondering if you can split down a whole piece of leather if you skived each area bit by bit...for example the backing of a leather wallet? Something of that size. thanks Quote
Members lilwaysleather Posted October 23, 2015 Members Report Posted October 23, 2015 I got mine used from cobra Steve. Look around and your u can find them used for a decent price. They aren't that complicated but there's definitely a learning curve. I can answer any specific questions you have about use. Andrew I know there is a learning curve but is it as difficult as some say? Some of the videos on youtube make it look pretty straight forward. Do you know the differences between the machines cobra steve has and the con sew s3-s4? Also interested in using it to split leather for certain projects, you can skive 2 edges on each side correct? so a piece the total of 4 inches across could be fully skived down from what Im understanding. Is there anyway to reach the center on something larger than 4 inches? thanks Quote
Members Andrew Chee Posted October 23, 2015 Members Report Posted October 23, 2015 I know there is a learning curve but is it as difficult as some say? Some of the videos on youtube make it look pretty straight forward. Do you know the differences between the machines cobra steve has and the con sew s3-s4? Also interested in using it to split leather for certain projects, you can skive 2 edges on each side correct? so a piece the total of 4 inches across could be fully skived down from what Im understanding. Is there anyway to reach the center on something larger than 4 inches? thanks The machine that I purchased from Steve was a Consew. It was a trade-in that he had. There's basically two kinds of bell knife skivers. Bottom feed only and top and bottom feed. The latter allows you to skive really heavy leather. They aren't as precise when you get down to the really thin stuff though. The main reason being there's a wheel on top that turns so it's not as precise as a stationary bar. As for your learning curve question, it's really not that hard at all. It's pretty easy. There's some things to keep in mind depending on whether you skiving thick or thin stuff or soft or firm but it's really not that hard at all. As for your question about doing multiple runs to thin an entire piece of leather. While yes that's doable by doing multiple runs, the results are not perfects. You may end up with some ridges and thicker spots because the knife, feed wheel, and presser feet are never exactly parallel. With that said, it's still doable. The results just aren't perfect. Hope this helps. Andrew Quote
