Members davecbnz Posted July 5, 2015 Members Report Posted July 5, 2015 I've just picked up a Juki lu563, i want to know what is the maximum size thread i can run through 6mm (just under 1/4")of veg tanned leather? I've read here #138 is max at 3/8" of leather, can i get away with thicker thread through 6mm of leather? Quote
Members Geneva Posted July 5, 2015 Members Report Posted July 5, 2015 The only way to use a larger thread is to take the bobbin cover and either mill more clearance or grind it out yourself from the slot that is cut in the underside of the bobbin cover. There isn't enough clearance between the top of the bobbin holder and the bottom of the bobbin cover for any thicker thread. You would not be able to run the larger thread in the bobbin just on the top. Good luck. Quote
Moderator Wizcrafts Posted July 5, 2015 Moderator Report Posted July 5, 2015 I agree with Geneva. I owned an LU-536 in 1989 and could not exceed #138 thread. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members davecbnz Posted July 6, 2015 Author Members Report Posted July 6, 2015 Thanks guys. Being a maintenance engineer I'll find it hard to not modify it. Quote
