Dye Edges How To Avoid Getting Dye On The Grain Or Flesh Side?
There are times that I want to darken the leather under the lacing so it doesn't contrast with the lacing when/if it shows through and to do that I use a sharpie. It works well and I find it very easy to control.
hi bob, question for you about using sharpies, did you have to set the sharpie ink in any way after it dried or did the color hold? i have been trying various markers and really like how they look but am wondering if i need to set them somehow .. i would rather not because setting might stiffen the edges and i prefer to keep them soft and pliable Edited by jhw
  • Replies 23
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
I'v never had to do anything on an edge to make the ink stay, however in my case it's going to be covered mostly by lacing. I have used Sharpies to color letters and found that when a wiped on Wyosheen (same as Clear Lac or Neat Lac) it did take a little of the ink off. That's the only time I've had a problem with the ink coming off. And after a thin coat of Wyosheen the ink seemed very sealed. I put thin coats of this on all my notebooks and it doesn't have any problems flexing, as long as you keep the coat thin.
Hope this helps,
Bob
There are always possibilities....
Bob Blea
C and B Leathercrafts
Fort Collins, CO
Visit my shop at http://www.etsy.com/shop/CandBLeather?ref=si_shop
Instagram @bobbleacandbleather
Hope this helps,
Bob
thank you Bob! that definitely helps. Edited by jhw
