My work boots have started coming apart at the stitching. I was thinking of buying a speedy stitcher and re sewing through the existing holes.
I would like to know if a tool like that would be suitable to do the this type or repair. They come with a coarse thread and I was not sure it that will be too thick?
Also I have read online that the needles in these snap easily, as if they are not the same quality as from years ago. Is it possible to buy better needles other than the speedy stitcher brand needles?
What are my other options in tooling for repairing these boots?
Peter
post-64689-0-06671900-1439287254_thumb.j
If you don't care how it looks, use the speedy stitcher. If they were mine, I would saddle-stitch to repair them. Other option is to take them to a proper shoe repair business and have them stitch them back up with one of their machines.
Peter,
Like 25 says, find someone with a patcher. See if you have a guild in your area and ask someone for help. Like said before, anyone here is just going to saddle stitch it, especially with the zipper access. As a second alternative, you could continue the tie-wrap line of binding for a completely unique and durable effect.
Art
You can skip the needle if you want. Take two paper twist tie, strip off the paper to expose the bare wire. Bend in half and twist to leave you with a tiny loop at one end. Feed your thread through that "eye" and hold the two loose ends together (your "needle point" to feed through the holes. If you don't have waxed thread, use white dental floss, which is usually nylon. It's an inexpensive way to keep your boots going, and will save the shoe repair bill.
In shoemaking, you can use monofilament fishing line as a kind of needle. Tie the thread to the mono. You can stick a shoemakers awl (kind of curved on the end) and while the awl is still in there, run the mono through, take out the awl and pull the thread through.
Art
