Members Bullfinch Posted August 23, 2015 Members Report Posted August 23, 2015 Hello there, I'm not sure if I'm posting this in the right section, but here I go. Does any of you know how to achieve nice, neat grooves along the edges like those: Is it simply the case of using a groover, or is there a better trick for that? It doesn't look like it's beveled. So how do they do that? *stares in awe*. Have any of you guys tried that? Quote
Members Halitech Posted August 23, 2015 Members Report Posted August 23, 2015 looks like just done with a groover to me, very carefully Quote Every day you learn something is a good day. If you don't learn something every day, was it worth waking up for?
Members Bullfinch Posted August 23, 2015 Author Members Report Posted August 23, 2015 looks like just done with a groover to me, very carefully hmmm to me too. but still it gets me wondering, maybe it's just pressed in with an awl or a tracing pen - hard pressed and as you said very carefully :}. Quote
Members Halitech Posted August 23, 2015 Members Report Posted August 23, 2015 the cases could be a stamp for all of it but the armour, I'd say was grooved Quote Every day you learn something is a good day. If you don't learn something every day, was it worth waking up for?
Members DavidL Posted August 23, 2015 Members Report Posted August 23, 2015 I grooved a wallet thinking it was good to go. Had water put on the leather to wash off some dirt and the grooves were hardly visible afterwards. Probably heat applied with the groover would be best. Quote
Members Bullfinch Posted August 23, 2015 Author Members Report Posted August 23, 2015 I grooved a wallet thinking it was good to go. Had water put on the leather to wash off some dirt and the grooves were hardly visible afterwards. Probably heat applied with the groover would be best. that's an interesting idea. thank you for sharing :}. Quote
King's X Posted August 23, 2015 Report Posted August 23, 2015 I usually wet the leather and then groove for my stitching channel. If I want to keep it as a way to decorate you will have to have a sharp groover or make multiple passes. Of course, we are talking about an adjustable groover so that you have the same distance during each pass. One of the best and sharpest groover is the one made by Bob Douglas available through Sheridan Outfitters in Wyoming, USA. Good luck Quote Greetings from Central Texas! The Grain Side Up blog #TheGrainSideUp
Members Wild Bill46 Posted August 23, 2015 Members Report Posted August 23, 2015 To Me, They look as if their first wide grooved, and beveled on one side of each line ! Wild Bill46 Quote
Members Bullfinch Posted August 23, 2015 Author Members Report Posted August 23, 2015 I usually wet the leather and then groove for my stitching channel. If I want to keep it as a way to decorate you will have to have a sharp groover or make multiple passes. Of course, we are talking about an adjustable groover so that you have the same distance during each pass. One of the best and sharpest groover is the one made by Bob Douglas available through Sheridan Outfitters in Wyoming, USA. Good luck thank you for the tip. I'll check it out. my current groover is adjustable but of poor quality, I've been looking for something better. Quote
King's X Posted August 24, 2015 Report Posted August 24, 2015 Have you tried stropping your groover tip? You can use unwaxed thread covered with rouge and run it through the tip hole. This usually steps up the quality of your cut a step or two. Good luck! Quote Greetings from Central Texas! The Grain Side Up blog #TheGrainSideUp
Members silverwingit Posted August 25, 2015 Members Report Posted August 25, 2015 In terms of maintaining the sharpness of my edgers, I get fine results using my Weaver Strop Board. http://www.weaverleathersupply.com/Catalog/ItemContent.aspx?ItemNumber=8708&CatalogId=001&CatalogDetailId=44&NSM=Y Michelle Quote
Members Bullfinch Posted August 26, 2015 Author Members Report Posted August 26, 2015 Have you tried stropping your groover tip? You can use unwaxed thread covered with rouge and run it through the tip hole. This usually steps up the quality of your cut a step or two. Good luck! In terms of maintaining the sharpness of my edgers, I get fine results using my Weaver Strop Board. http://www.weaverleathersupply.com/Catalog/ItemContent.aspx?ItemNumber=8708&CatalogId=001&CatalogDetailId=44&NSM=Y Michelle thank you guys. I'll try sharpening it before I start looking around for a new groover :D. Quote
