To those that use edge paint with a heated tool, how well does the paint adhere to small amounts of glue that are sanded smooth (right betwwen layers). Would there be any issue with the paint not adhering?
White glue, fiebings cement to be exact. Im switching to contact cement soon.
So far the glue can be seen slightly between the two pieces of leather. With regular edge dye the glue obviously wont soak into the glue the same the leather. Im guessing its the same with edge paint?
Best bet would be to get the glue to not show but on a large bag im sure some glue will show up between the edge.
You need to cut or sand the glue off the edges and bring them down to a 300-400 finish before applying edge coat. Glue can be made thin with solvent so that it goes on in a thin coat and is not in such excess that it squeezes out. Care should be exercised in application so as to avoid putting glue on the edges.
Art
