jk215
Adjusting Presset Foot Tension On 206Rb-5?
Hello all. Getting a lot of feed dog track marks on the bottom of my work and looking to remedy. I wanted to try reducing the presser foot tension but having trouble locating some instructions. Couldnt find anything in the manual or guides. Can anyone help? Thanks!
There is a hole behind the spool pin on top of the machine that you put a screwdriver in & turn to the left to loosen.If you look @ the back of the machine you can see the long flat spring & where the screw makes contact w/it.
