JamesR Report post Posted November 29, 2015 Hello, I want to make a centering jig for belt punches. Does anyone know what the diameter of the shank(not the hole) is for the different punches on the market like Osborne, Weaver, etc I want to make a guide hole for the shank of the punch to slide into. This would be a problem if the shank diameters are all different. Thanks Quote Share this post Link to post Share on other sites
TwinOaks Report post Posted November 29, 2015 The diameters of the two 1/4" punches I have are right at 3/8th". Every sized punch has a different diameter shank...but I don't have Weaver punches, so I can't speak on them. You might consider using a Jacob's chuck to hold the shank - that way you have an adjustable way to hold anything up to ~1/2" (common drill bit chuck size). Quote Share this post Link to post Share on other sites
Nuttish Report post Posted November 29, 2015 Weaver makes a centering jig for hand work that's compatible with their round and oval punches. Quote Share this post Link to post Share on other sites
Colt W Knight Report post Posted November 29, 2015 (edited) My weaver oblong punch has a square handle, not round. Due to the nature of how these tools are manufactured, sanded, and polished, I would imagine there is tremendous variation among tools of the same brand. Edited November 29, 2015 by Colt W Knight Quote Share this post Link to post Share on other sites
JamesR Report post Posted November 30, 2015 Thanks for the replies. Colt, I was not too clear. I was only referring to round punches. A centering jig for the oblong punches would be good too. I have Weaver oblong punches and what you say is true. I want to make a jig similar to the Weaver jig. I was hoping to save some money on the punches. If the Osborne shanks are different diameters then I will have to reconsider. Quote Share this post Link to post Share on other sites
Nuttish Report post Posted November 30, 2015 My weaver oblong punch has a square handle, not round. Due to the nature of how these tools are manufactured, sanded, and polished, I would imagine there is tremendous variation among tools of the same brand. I'm not talking about oblong punches. You'd have to make your own jig for those with three pieces of leather. I'm talking about Weaver round and oval punches. The Master Tools range are compatible with Weaver's adjustable centering jig. See: http://www.weaverleathersupply.com/Catalog/ItemContent.aspx?ItemNumber=29291&CatalogId=001&CatalogDetailId=42&NSM=Y Quote Share this post Link to post Share on other sites
Nuttish Report post Posted November 30, 2015 ... I want to make a jig similar to the Weaver jig. I was hoping to save some money on the punches. ... You can make a workable jig with three pieces of leather. Two layers — the top has your punch holes centered for whatever width you need. The bottom layer is two pieces that center your strap under the holes stitched to the top. This is a step up from the standard single layer template people use. Makes it easier to crank blanks out without thinking. Quote Share this post Link to post Share on other sites
Colt W Knight Report post Posted November 30, 2015 Al my CS Osborne hole punches have different diameter shanks. Quote Share this post Link to post Share on other sites
