Thanks everyone. I am having some issues with edging. I dye the edges and use edge paint. The problem is the edge paint is coming off.
Here is my process:
After gluing and stitching the belt I use a 220 grit sander to even up all edges.
I then use a 1000 grit sanding sponge to further slick the edges and then use 1,200 sandpaper.
Then I use a #3 western edger to round all edges
After that I use a burnisher in a drill press and take a few passes over the belt with a wet edge.
I then dye the edges (black usually) using a Fiebings edge dye
After the dye has dried I use Fiebings yellow saddle soap and a canvas cloth to slick the edges smooth.
After that dries I apply edge paint.
I'm thinking about skipping the edge paint because its coming off when the buckle rubs the belt. The edge paint makes the edge look better when its new but makes it look like crap after just a few times being worn.
Any ideas?
I'm still trying to figure out edges myself, and have yet to test edges for durability, but the consensus, as far as I have read, is that applying any kind of edge-slicking soap, gum trag, or anything like that before applying edge paint will make it so the edge paint cannot adhere properly to the edge. Basically, if you're going to use edge paint, don't use saddle soap or wax first. Dispense with the soap entirely and wax and burnish after the edge paint has cured.
