Members lb61906 Posted January 14, 2016 Members Report Posted January 14, 2016 Hey Guys, Looking to get my first set of Vergez Blanchard irons. I mostly make smaller leather goods (wallets, passport covers, etc) and some tote bags. Not sure which size would be the best place to start. I was thinking the #9 would be a safe set to start out with. Your thoughts? 6 Stitches per Inch - Dist. between teeth 4.5 mm 7 Stitches per Inch - Dist. between teeth 3.9 mm 8 Stitches per Inch - Dist. between teeth 3.4 mm 9 Stitches per Inch - Dist. between teeth 3.0 mm 10 Stitches per Inch - Dist. between teeth 2.7 mm 12 Stitches per Inch - Dist. between teeth 2.5 mm Quote Check me out here: https://www.instagram.com/cjohnsonleather/
Members Django57 Posted January 14, 2016 Members Report Posted January 14, 2016 This an example of a number 9 Blanchard iron if that helps with your choice , it's on a passport wallet Quote
Members lb61906 Posted January 14, 2016 Author Members Report Posted January 14, 2016 Thanks! That looks good, but this make me think #8 is a better option for me. Quote Check me out here: https://www.instagram.com/cjohnsonleather/
Members Django57 Posted January 14, 2016 Members Report Posted January 14, 2016 No problem it's worth doing your research as they're not cheap good luck . Quote
Members SmokeyPoint Posted January 27, 2016 Members Report Posted January 27, 2016 Here's a comparison I did with various sizes of Blanchard irons and different threads, hope this helps... http://leatherworker.net/forum/index.php?showtopic=67652 Quote http://www.smokeypointleather.com
