I use a #3 edger on my holsters and it works well.
I use 5 per inch on my stitch holes.
The problem you are likely having with fit is the difference in thickness of the guns. I'm sure you notice where you could tighten up the stitch line around the trigger guard. If you also want to compensate for the thickness you could do that by moving the stitch line on the slide side in an appropriate amount. Then you will be started figuring out how to make your own patterns. Generally speaking you can trace the outline of the gun, measure the thickness, add half that measurement all the way around the gun, and that gets you pretty close to the stitch line you need. You could then transfer that stitch line onto that pattern and go for it to check.
