Just curious. I'm new to this and am cutting reins from a huge 16/18 harness side. I wound up cutting them with a round knife. How thick of leather can a wooden strap cutter adjust to?
I've cut 13 / 15 oz skirting. That's about the limit.
Edited by dirtclod
I'm old enough to know that i don't know everything.
Depending on which wooden strap cutter you are referring to it may depend on the pass through.
It also would depend on the blade sharpness, quality and whether it is mounted right. If a cheap blade is a little crooked in thinner softer leathers, it may work but throw in some stiff leather at the max thickness of the cutter, and if that blade isn't straight and parallel to the frame, it may wander, flex and break.
"If nobody shares what they know, we will eventually all know nothing."
"There is no adventure in letting fear and common sense be your guide"
Well, after some experimentation I've decided that 16 oz is about the thickest I can get to even fit in it. This is the one that I have.
I definitely noticed some wander with the thicker leather. Good to know, thank you!
post-68618-0-15065000-1454203203_thumb.j
