Personally, 1 lb for most work, 3 lb for shading and geometrics and 8 lb for die cutting and punching
Oltoot, thanks for the reply, why the heavier wt for shading is it because it needs to go deeper. New to this and want to start moving toward tooling.
Peter
For general tooling, I use an 8-10 oz maul.
Greetings from Central Texas!
The Grain Side Up blog
#TheGrainSideUp
KingX, so you go 8-6 oz less, why is that your preference, I have seen your blog spot and can see you are turning out nice work.
Thanks for the reply.
Peter
