raysouth Posted February 12, 2016 Report Posted February 12, 2016 Hello Folks, I am beginning a search for a foot operated grommet/rivet/spot setter that is not extremely expensive and dies and accessories are reasonable. Any suggestions? Assistance heading me off in right direction would be appreciated. God Bless. Ray Quote
Members TomG Posted February 12, 2016 Members Report Posted February 12, 2016 2 that come to mind right away goldstartools.com standardrivet.com Quote
Members billybopp Posted February 13, 2016 Members Report Posted February 13, 2016 Ray: They make dedicated foot operated setters, but from what I've seen they are pretty pricey. Pricey is probably the way to go if you intend on full-blown production line work, but for lower volume I'd give some thought to a Goldstar or something similar and adapt it to foot operated with a homemade pedal and strap of some sort to operate it. Just a thought Bill Quote
raysouth Posted February 15, 2016 Author Report Posted February 15, 2016 Thank you Bill and Tom. Took a look at Goldstar unit for $300.00 and also considering the fabrication of a unit as you suggested, Bill. Eglideride emailed me a pic of a unit that someone had made and it may be the way to go as I have the Goldstar bench setter and a couple of dies in house. Having to work from a seated position, I will have to come up with a way to multiply the applied force as won't be able to apply full body weight. Did locate a stand for $39.00 at Harbor Freight and with 20% coupon that may be the ticket. It is adjustable to several height positions and that is also a plus for me. Hope I can pull it off and thank you for the suggestions. God Bless. Ray Quote
