Is there a recommendation for how far you stitch lines should be from edges?
Re-read the pinned How To and see that I missed the line is 1/8" from edge.
Do you guys use double stitching (2 needles) or single stitching (1 needle). Seems the double is better.
Edited by JRB
ΜΟΛΩΝ ΛΑΒΕ
I set mine 3/16 in. I would saddle stitch - 2 needles. Looking forward to seeing what you're working on. Good luck with it. ~Bill
I try to be about 1/4" or a little less from the edge. Which allows for the beveled edge not to crowd the stitch line and I found that the edge does compress somewhat towards the stitching after burnishing usually making it look ok.
Edited by Jordan
