ttownfire Posted December 15, 2008 Report Posted December 15, 2008 What size needle would you run for 138 thread? I'm thinking 23 as I run a 22 for 92 thread... could it be 24? Quote Michael Martinez Caffeine Industries
Members Oscar B Posted December 15, 2008 Members Report Posted December 15, 2008 This may help. http://www.sailrite.com/Which-Thread-or-Ne...34Pa38Ta38Pbxn0 Quote Life is too short to wake up with regrets. So love the people who treat you right. Forget about the ones who don't. Believe everything happens for a reason. If you get a chance, take it. If it changes your life, let it. Nobody said life would be easy, they just promised it would most likely be worth it."
Moderator Art Posted December 15, 2008 Moderator Report Posted December 15, 2008 With Coats poly I run a 19 needle. You will get the occasional thread break, but the look with the smaller holes is nicer and you can also increase the spi. Art What size needle would you run for 138 thread? I'm thinking 23 as I run a 22 for 92 thread... could it be 24? Quote For heaven's sakes pilgrim, make yourself a strop!
esantoro Posted December 15, 2008 Report Posted December 15, 2008 With Coats poly I run a 19 needle. You will get the occasional thread break, but the look with the smaller holes is nicer and you can also increase the spi.Art Art, Can you use the 19 needle/138 thread in your Artisan cylinder arm machine without changing anything other than maybe bobbin tension? Ed Quote http://www.waldenbags.com http://www.waldenbags.etsy.com
Moderator Art Posted December 15, 2008 Moderator Report Posted December 15, 2008 Hi Ed, I use the 19 in the 618, works without much adjustment using 138/138 Linhanyl Nylon or Coats poly, just a little tension tweak. I never set the big machines up to do anything under 207, I suppose a #19 might be a little far from the hook. You'll just have to try it. Art Art,Can you use the 19 needle/138 thread in your Artisan cylinder arm machine without changing anything other than maybe bobbin tension? Ed Quote For heaven's sakes pilgrim, make yourself a strop!
