Members MY63 Posted March 12, 2016 Members Report Posted March 12, 2016 My most recent project involves a case made in two parts an inside and an outer cover. Both parts are ready to be attached together my problem is I cut the first cover with the case open and when I closed the case the outer was too short. so I have made another outer cover. My question is if I glue and sew the inner piece what happens to the extra material when the case is opened I hope this makes sense Quote I have recently started my own blog to share more detail of my projects http://my63leather.wordpress.com
Members Halitech Posted March 12, 2016 Members Report Posted March 12, 2016 I would avoid gluing the middle section where it bends. When you made the inside section, it should have been about 1/2" shorter then the outer piece to allow it to bend closed, same principle as a wallet. Quote Every day you learn something is a good day. If you don't learn something every day, was it worth waking up for?
Members MY63 Posted March 13, 2016 Author Members Report Posted March 13, 2016 Thanks for the prompt response. I realised my mistake when the cover did not fit the closed case so I made the spine piece overlap as you can see in the picture. Your reply was very helpful Quote I have recently started my own blog to share more detail of my projects http://my63leather.wordpress.com
Members MY63 Posted March 14, 2016 Author Members Report Posted March 14, 2016 I thought you might like to see how the case turned out I just need to finish the edges. Quote I have recently started my own blog to share more detail of my projects http://my63leather.wordpress.com
Members Halitech Posted March 14, 2016 Members Report Posted March 14, 2016 looks good. I really like the color combination and with a little modification you could use it for a bible case or artists case. Quote Every day you learn something is a good day. If you don't learn something every day, was it worth waking up for?
