Members SteelheadFineGoods Posted March 29, 2016 Members Report Posted March 29, 2016 I recently acquired a D.B. Die Works No. 39 kick press. It is currently without a stand. Before I go ahead and build my own stand for it, do any of you out there have the original stand for this kick press for sale? Also, can you suggest a good source to purchase dies for this machine? I will be looking for dies for Line 20 and Line 24 snaps. I appreciate any help I can get. Thanks! Quote Steelhead Flickr Instagram Tumblr
Members Latinodesign Posted September 10, 2023 Members Report Posted September 10, 2023 I also got the same machine without stand and I made the stand myself. You can by the table stands (legs) at walmart or home depot and get a piece of wood for the top I wanted to send you a photo of the stand but it doesn't pass Quote
Members Cumberland Highpower Posted September 13, 2023 Members Report Posted September 13, 2023 On 3/29/2016 at 4:49 PM, SteelheadFineGoods said: I recently acquired a D.B. Die Works No. 39 kick press. It is currently without a stand. Before I go ahead and build my own stand for it, do any of you out there have the original stand for this kick press for sale? Also, can you suggest a good source to purchase dies for this machine? I will be looking for dies for Line 20 and Line 24 snaps. I appreciate any help I can get. Thanks! Expand They're an obsolete maker, but you can work up about anything for a stand. Even a harbor freight stand for a sander etc might work? Snap dies, you can work up something I think. Weaver leather, Dot Fastener, probably more. Ohio travel bag, etc. Quote
Members shoepatcher Posted October 25, 2023 Members Report Posted October 25, 2023 Contact Siska in NJ. They rebuild all types of eyelet, rivet, grommet machines and make dies. I have had them make a few for me. glenn Quote
Members margot Posted October 25, 2023 Members Report Posted October 25, 2023 I found a D.B. Die Works n. 39 kick press on marketplace recently, it came without dies, the diameter of the holes on my press is 9mm (I used a caliper tool to figure out the diameter of the hole, which I recommend you do the same) -- I figured out Tandy Leather dies fit nicely, I tried to use other brands but found the height on the DB die works press was too high for most. If your press also takes 9mm dies then I recommend seeing if their 'hand press dies' work, the rivet dies at tandy come in a three pack and they have line snap dies. Quote
