Is there any way to edit the filters for unread content? Under Activity, My Activity Streams?
One of the Default streams has a filter I never use and cant delete it. Specifically, the default Unread Content stream, the first filter is BDSM only... which while nothing wrong with that it shouldn't be the default.
When I click the Unread content link it should default to  all unread content.
Thanks, Craig
Yep, you can create a blank stream that includes everything or filter it how you want, name it whatever you want and set it as your default.
1. Click 'unread content' to open the default stream.
2. Open the first drop-down and 'X' the bdsm tag to clear the box.
3. Set your preferences from the row of drop-down boxes. Leave everything blank to include all new content.
4. Click 'save as new stream' and give it a unique name eg 'My Unread Content'.
5. Next to the stream name at the top are three little icons, a pen, a dustbin and a tick. Hover your mouse over the tick to highlight the option. Select it and your custom stream is now your default.
Edited by Martyn
I can't find the unread content?
where do I look?
where do I look?
Here...
Or here...
Edited by Martyn
I finally figured out if you hit that page looking icon in the black bar, then hit activity it will bring up new post.
that filter thingy isn't working at all no matter what I set it on and save...
Would be nice just to have the new posts button back...
It'll be back. Have a ticket in on it now. Thanks for typing that out Martyn.
~J
You cannot depend on your eyes when your imagination is out of focus. - Mark Twain
That's what I was looking for.
Now if we could edit the list?
Thanks a lot!
Unfortunately, it only changes the 'unread content' link on the top right corner. The links in the top menubar/header gets added to, rather than replaced. I'm sure Johanna will figure it out, these things take time. :)
I think the stuck tag is gone now. Try it out and let me know if you are still having problems. Thanks!
