Members Darren Brosowski Posted May 18, 2016 Members Report Posted May 18, 2016 Bobbin is not threaded correctly in this picture. From inside the thread faces up and you pull it down though the slot, under the tension spring then up through the guide hole Quote
Members Constabulary Posted May 18, 2016 Members Report Posted May 18, 2016 2 hours ago, Darren Brosowski said: Bobbin is not threaded correctly in this picture. From inside the thread faces up and you pull it down though the slot, under the tension spring then up through the guide hole Not sure what you see but for me it looks correctly threaded for a large bobbin hook. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members shoepatcher Posted May 18, 2016 Members Report Posted May 18, 2016 C, That large bobbin is correctly threaded on the patcher. glenn Quote
