Finished up my first bib spur straps. I forgot to bevel the edges, other critique is appreciated!
Maybe should add a belt keeper too
I think they came out pretty good for a first pair. I don't know about a keeper, it wouldn't be hard to rig up but I would wear them for a while and see if the strap curls too much or catches on stuff first. Thanks for posting them.
David
  • 4 months later...
Pretty good for a first pair.  If you're going to make more, maybe you'd consider tapering the ends of the buckle strap so that they lay flatter.  Also, unless you're going to use a center-bar buckle, you'd want a keeper on the outside of the buckle to tuck it away. Then, just for aesthetics, consider surrounding your carving with a crease instead of a single tick line.  It will make a huge difference in the perceived quality of your work.
Edited by cowboycolonel
spelling error
