At what angle should a round knife be sharpened? Just got a Ken Onion Work Sharp and hope the round knife bevel is one of the preset angles on this sharpener.
C. Norman McGlohon
Chapel Stone, LLC
Custom Leather Works
It really depends on you.  You can make it as sharp as you want, down to about 10° per side if you want, that is a 20° included angle and requires a lot on your part to keep it that way.  Read stropping continuously, not pushing into the cutting surface and sticking with pretty good supple condition leathers.  I have a couple of knives sharpened this way, but I know very well their limitations, a harder leather will round them over quickly.  A more reasonable angel is 15° to 20° per side for an included angle of 30° to 40°.  Depending on the knife steel, these hold-up very well, even in very tough leather.  A 30° included angle is very easy to sharpen with a secondary bevel, and can be sharpened quite a few times before a regrind.  Now, you're going to hate me, but it is what you and your knife likes, and your sharpening skills.  The Ken Onion WorkSharp is a pretty good choice for the home sharpener, we use something similar, but a bit bigger.  The nice part about the KO, is that you have it, and that means your knife SHOULD always be sharp.
Art
Thanks, I am new to sharpening. Would you suggest I set angle jig to 20 and then follow their instructions? I have been trying to use a diamond stone 1200 grit but I am not getting the angle consistent..
C. Norman McGlohon
Chapel Stone, LLC
If 20 is the included angle, no, read the directions.  You should probably start a 20° PER SIDE, for an included angle of 40°.
Art
I just got it and need to read instructions. The wheel is marked 15 to 30 degrees in 5 degree increments.
C. Norman McGlohon
Chapel Stone, LLC
On the worksharp we use (mostly as a handy flat hone) all the angles are side angles, not included angles.
Art
Thanks for your help.
C. Norman McGlohon
Chapel Stone, LLC
Whadidesay?  Actually, I have found that listening to him for a half hour or more will tune your ear to his rhythm and pronunciation.  Then watch again or even another video and it will be much clearer.  Train the Brain.
Art
I understand every word I say.  Then again I have to listen to myself every day. Ah such wonderful harmonics.
www.uksaddlery.com
Saddlery training courses in Dunoon Scotland UK.
