Members sdkid Posted December 28, 2008 Members Report Posted December 28, 2008 This was my fil's. He is gone now, and I have decided to try his old singer out. I got it oiled up and turning good. I can't get it to pick up the bottom thread. I found a manual online, and I think it is set up correctly. Any ideas? Quote
Ambassador Luke Hatley Posted December 28, 2008 Ambassador Report Posted December 28, 2008 hate to ask .......is there thread in the bobbin ? and the bobbin threaded correctly.? Quote Luke
Members sdkid Posted December 28, 2008 Author Members Report Posted December 28, 2008 The bobbin has thread, but it could be wound backward I guess. I'll check that shortly. Quote
Members sdkid Posted December 28, 2008 Author Members Report Posted December 28, 2008 I checked and I think it is wound correctly. I think it is threaded through correctly too. Quote
Members ryano Posted December 28, 2008 Members Report Posted December 28, 2008 It will not pick up while trying to sew? I have never tried to pick up the thread while threading my machine, I just pulled the thread through the bottom hole. Also make sure the plate above the bobbin is facing the correct way, counter bore above the bobbin. Also oil the bobbin gears well. The needle may be too far away from the bobbin. This is adjusted by the screw above the needle screw. The needle should be as close to the bobbin hook as possible without hitting it. One other thing, use only 29x4 needles for leather and 29x4 needles for cloth. Quote
Members sdkid Posted December 28, 2008 Author Members Report Posted December 28, 2008 Well, the manual says it should. I will try feeding it through and see what happens. Speaking of needles, If I read it correctly, the eye of the needle should face the machine and not me. Does that make sense? The eye of my needle faces me. I bought a needle at walmart and it is the same. It as a singer #30030, style 2020, size 110/18. Would this cause it? I don't have a local supplier for the correct needle. I will have to order online. Quote
superchute Posted December 28, 2008 Report Posted December 28, 2008 the sewing center in rapid city should have what you need there. There nice fokes and try to help. Russ Quote
Members SteveBrambley Posted December 28, 2008 Members Report Posted December 28, 2008 Well, the manual says it should. I will try feeding it through and see what happens. Speaking of needles, If I read it correctly, the eye of the needle should face the machine and not me. Does that make sense? The eye of my needle faces me. I bought a needle at walmart and it is the same. It as a singer #30030, style 2020, size 110/18. Would this cause it? I don't have a local supplier for the correct needle. I will have to order online. The long groove, above the needle eye, MUST face to your left, that is, away from the main body of the machine head casting. If it faces in any other direction the machine will not pick up the stitch! Steve Quote
Contributing Member rdb Posted December 28, 2008 Contributing Member Report Posted December 28, 2008 If it's anything like my adler, when loading the bobbin, make sure the thread goes under the spring completely. I actually have to use a small tool to push the thread under it good. Once done, everything runs smooth. This was KEY to having my machine pick up the bobbin thread!!!!!!!!!!!!!!!! Quote Web page Facebook
Members sdkid Posted December 28, 2008 Author Members Report Posted December 28, 2008 The long groove, above the needle eye, MUST face to your left, that is, away from the main body of the machine head casting. If it faces in any other direction the machine will not pick up the stitch!Steve It must have had the wrong needle in th first place then. If I set the screw against the flat of the needle, the eye faces me with the long groove facing away from me. I'll call the Sewing Center as superchute suggested and see if they can get what I need. Thanks everyone, i'll let you know how it goes. Quote
