Thanks plinkercases.  I figure on doing one more practice run before I try it on a holster.
Steve
"No man is above the law and no man is below it; nor do we ask any man's permission when we ask him to obey it." Theodore Roosevelt
if you put the stitch line a little closer to the edges you get a little more room for them on the plug.
"Oh my God....I beseech thee grant me the grace to remain in Thy Presence; and to this end do Thou prosper me with Thy assistance, receive all my works, and possess all my affections" Brother Lawrence c.1614-1691
plinkercases.ca
Thanks, plinkercases.  I appreciate the advise.  I have my stitch line at the muzzle of the holster and the toe plug at 3/16".  It seems like many of the pictures in Packing Iron show the stitch line is closer then what I am using.  I can try setting my stitch line for the muzzle of the holster and toe plug at 1/8".  I don't think it would be safe to go any closer to the edge.
I just completed a second trial run.  It was much easier this time.  I had an easier time getting the angle right on the awl.  I will have to revise my pattern as it will likely be to tight around the muzzle based on my two trials.
Edited by Steve75
Steve
Looking forward to the results and shared lessons learned.
plinkercases.ca
Personally I like the Slim Jim/California style with the sewn in plug.
Second choice is squared but open then round sewn.
Why not try the sewn plug?
My preferences mimic yours.
Here's how I do a sewn toe plug, learning from Ghormley. I also set my stitch groove about 3/16" from the edge (on the holster). I pre-punch the holes in the toe at the same 7 stitches per inch spacing, before gluing/stitching the mainseam but I do it at a 45° angle. I make my plugs out of doubled 8-9oz with the flesh sides glued together. I make them a rough shape and then final shape them on the belt sander. Then cut my stitch groove closer to the edge than the rest of my work. I then glue the plug into the toe. I then carefully punch my holes with a smaller awl because the holes will be closer together than the outside. I still stitch with the same thread but use a smaller needle. I sometimes even work it out so that I stitch the mainseam and the toe plug with one continuous thread. I come around the toe and then backstitch four stitches up the mainseam.
Edited by Craig44
Typos
Nice job and good tips. I also continue around from the main seam. Goo trick to predo the holes on the body and use them as a guide for the plug holes with a smaller awl. clever.
plinkercases.ca
If you don't have a smaller awl, you can always penetrate the plug with "just the tip" of your regular awl. Rather than pushing it all the way through.
