Well after posting a couple of crappy wallets I made it took the advice of a few people and made this little knife sheaths. I still have a long way to go but I can tell a difference with saddle stitching and better leather.
  • 3 weeks later...
lets start at the top:
1. your knife will cut through your sheath. reason is you need to apply a center rib. this rib goes between the two sewn sides of the sheath.
2.  most do not want the knife handle rubbing on their side, so you could lengthen the belt loop to drop the knife down.
3. trim your edges to be the same length from stitch to edge & burnish. this gives a clean look
