Members threepets Posted October 27, 2016 Members Report Posted October 27, 2016 This #46 Nylon thread I just purchased is flying apart or fraying while I'm sewing . Would you say that perhaps this is an old product or is this common with some thread? I have sewn for years and always see a bit debris , but this is from about 45 to 60 seconds of sewing. Quote
Members TomG Posted October 27, 2016 Members Report Posted October 27, 2016 Check the needle. Possibly worn out. Check the feeder plate for burrs. But first, check your tension and make sure nothing is snagged or threaded wrong. Have you ever used 46#? I don't know about your machine, but I seem to recall 69# is the smallest my machines will handle (111W155 and 227R). There is also left and right twist threads. You said it was just purchased, so maybe the wrong twist? Post what you find. Helps us all <g> Quote Tom Gregory Legacy Leathercraft www.legacyleathercraft.com www.etsy.com/shop/legacyleathercraft
Members Sonydaze Posted October 27, 2016 Members Report Posted October 27, 2016 Since it is a new thread, that could be the problem. As far as the machine, I would try in a new needle (suggested size 14 or 16 for #46 thread). I would also turn the inside presser foot so it is not so close to the needle. Quote http://www.bound2please.com Sewing machines: 3 - Sunstar 590BL, Artisan Toro 3200, Juki LK-1900HS, Juki DDL-8500-7, Juki DDL-5550N, Pfaff 138-6/21, Pfaff 546-H3, Pfaff 335-H3, Adler 221-76, Singer 144WVS33, Singer 29K-51, Siruba 747B
Members TinkerTailor Posted October 27, 2016 Members Report Posted October 27, 2016 Is there shredded thread up around the tensioners as well? If it is up there too, you can probably rule out needle problems, however the foot does look too close to me as well. Quote "If nobody shares what they know, we will eventually all know nothing." "There is no adventure in letting fear and common sense be your guide"
Members HobbledCobbler Posted October 28, 2016 Members Report Posted October 28, 2016 When I worked at an upholstery fabrication shop, I actually had a needle which had an eye with a burr in it. It didn't come out of the box that way, it just developed a burr. Started cutting thread, regardless of which spool we used. The mechanic stated that occasionally happened. He'd seen it before. Changed the needle and the problem went away. Quote
Members HobbledCobbler Posted November 2, 2016 Members Report Posted November 2, 2016 On 10/27/2016 at 3:22 PM, threepets said: This #46 Nylon thread I just purchased is flying apart or fraying while I'm sewing . Would you say that perhaps this is an old product or is this common with some thread? I have sewn for years and always see a bit debris , but this is from about 45 to 60 seconds of sewing. Expand Well, did you solve your thread problems? Quote
